I started making knifes about two weeks ago, I have avoided knife making for a long time, I just felt a bit odd about it. Perhaps because to make a nice knife it requires a lot of nit-picky detail work. Well I got board, so on to something new. After slitting some 5160 truck leaf springs and forging out and getting two blades mostly ground I started thinking about heat treating. I intended to do them just like any tool, but got to thinking about it, so I went to some bladesmithing forum sites to see how the pros did it, and at first I found many people doing it just as I intended. However, looking a little closer at more experienced makers, most have very specialized equipment to do it right. The most controlled method seems to be salt baths like heat treaters use, a high one to bring and hold the blade to just the right temperature and one to quench to just the right temperature. Very controlled and scary if misused. I’m using a coal forge and well I find it’s not all that easy to control temperature evenly especially for long stock without a rebuild and not very friendly to any quench oil. I know I could buy some 1080 and use water but that would be too easy. To gain a little control I’m in the process of building a gas forge, if I live long enough I’m hoping to get an induction forge from Grant. I have a ton or high temp (the 2600 degree soft white kind) bricks, and am in the process of getting the burner design and materials together. I’ve thought about building a baffle to keep the flame off the stock and even out the heat, I have watched guys on youtube playing with blades in the forge to even the heat, does not look like fun or a very reliable method. The crayon or ribbon burner thread in this section looks interesting, but the thread died with little information. Not knowing anything about them or how well they work makes it hard to spend a lot of time figuring out how to make one. So what do you guys think about using a baffle, they may not be necessary or may be detrimental in an open forge as I have not seen one in a forge just in fuel burning kilns, but I don’t get out much. Do multiple burners help even out internal temperature? Does anyone have advice or opinions on gas forges?
Bob
